"steamed up" oil pressure gage
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by GT52, Apr 10, 2006.
  1. GT52
    GT52 Active Member
    The original Stewart Warner oil pressure gage in my KR "steams up" with what is obviously water vapor when the car is driven...not so bad you can't see thru the glass, but bad enough to be noticeable. Anyone else seen this??? know what causes it??? know how to fix it???
  2. TLEA
    Thats interesting because its not really a sealed unit. I'm assuming its an original guage. The originals came from SW's marine line so they were designed to run in damp conditions. The only way water (moisture) can get in there is thru the lamp socket. Are you in high humidity?
    Tim
  3. GT52
    GT52 Active Member
    Yea, extremely high humidity...I live north of San Francisco and less than 1/2 mile from the ocean. I know that contributes, but it seems to do it even mid-summer on sunny days??? It is the original S-W gage.
  4. TLEA
    There could be a film of some foreign material on inside of lens. Problem is the guages (at this point) are not servicable. I am looking into having repro bezels and crimping press made so guages can be cleaned and faces rescreened. If I get enough interest I may do it. I have about 2 dozen original guages most of which have faded faces.
    Tim
  5. GT52
    GT52 Active Member
    TLEA, that film's an interesting theory. I didn't add originally that the alternator gage, which appears to have near identical construction, does not "steam up". I wonder (out loud) if I could "wash" the gage out with something like an electrical contact cleaner without damaging it???
  6. TLEA
    I'd be worried about the cleaner discoloring the face. Oil guages are hard to come by. I pickup about 10 Alt guages to every oil guage. I have removed/reinstalled bezels with some success but it isn't perfect.
    Tim
  7. d_ford
    d_ford Well-Known Member
    Nelsonville, Ohio
    GT52.....I can't help answer why, but the oil pressure guage on my old 67 GT500 did the same thing. In the underdash guage unit the oil pressure guage steamed up but the ammeter was fine. It must be because it's a mechanical guage and warm oil goes into the line supplying it. The warmth from the oil coupled with high humidity must be the cause for steam. I even tried baking it out in a low temp oven but it would always come back.
  8. TLEA
    68 Greenlines are electric.
    Tim
