Tach with Duraspark II
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by di81977, Aug 10, 2006.
  1. di81977
    di81977 New Member
    Hope I am not bothering anyone, but I can not get an answer to my question from other mustang forums and thought I would try here.
    Without going into a lot of details, I have a 68 Mustang with Tach and recently installed a duraspark II ignition. No one seems to know how I reconnect the factory tach to the new electronic ignition.
    Has anyone with a 68 GT350 or 500 installed electronic ignition and if so, how did you reconnect the tach?
    I really appreciate the help!
    David
  2. Texas Swede
    I have electronic ignition, Pertronix with coil
    and cables on my Shelby 67 and I never did anything
    to the tach hook up. All the tachs for early Mustangs are
    connected to the positive side of the coil through a resistor
    wire. Very important to use the wire or a resistor to reduce
    the voltage over the coil after the car has started and is running.
    Hope it helps,
    Texas Swede
