Dear all I'm about to replace the set of tires I have on my '66 GT 350H. I was really seeking some suggestions from other owners about what to fit my car out with. The wheels are the standard magum 500's, I'm currently running Goodyear Eagle GT+4 at size 215/60R14. Any advice? Thank you Ian '66 # 845
Electrical Problem/Question My 68 GT 500 has an electrical problem. When the lights are turned on, tailights are fine, but nothing up front comes on. Fog lights work fine. Positive voltage is on all leads (including ground) going to parking, head, and side marker lights. The high beam indicator and both turn signal indicators light up. When I activate the turn signal lever, the appropriate lights but does not blink. Do I have a bad headlight switch? Positive voltage to all legs of the headlight dimmer switch. Putting 12 volts and ground individually to each light they work fine. Any ideas to shortcut my troubleshooting? Thanks, Rick Thompson
