Traction control warning...?
Discussion in '2nd Generation Shelby Mustangs' started by rdrumm, Oct 11, 2010.
  1. rdrumm
    rdrumm Active Member
    Anaheim Calif
    Thought this would be the best place to get an answer to this...
    This morning I got to work and punched it a little too hard... I started drifting.
    Lights flashed, warning buzzard started sounding... as soon as I let off and got back straight it stopped. What was that? It was scary enough being sideways, but I could have done without all the noise and flashing lights! What's up, and how do you turn that warning off?:grrr:
  2. wylie
    wylie Well-Known Member
    Lone Oak, Texas
    I would like to hear the answer also. Did you have the T/C on or off at the time?
  3. rdrumm
    Anaheim Calif
    Traction control was on.
    I believe when you to turn it off the light on the switch comes on telling you it is off! I will go out to the garage and check.
  4. rdrumm
    Anaheim Calif
    Traction control was on... unless you turn it off it's always on. Which brings up the next question... why would you turn it off?:mellow:
  5. wylie
    Lone Oak, Texas
    The drag racers turn it off. Cannot do a burn with it on. You will eat a wall.
  6. wylie
    Lone Oak, Texas
    You might get a quicker answer if you go over and sign in at the GT500 forum. Lots of racers over there.
  7. rdrumm
    Anaheim Calif
    Don't want to eat a wall! Not a drag racer, just testing out this beast [learning how to control it]! Glad it was the parking lot at work... so much power. Now I at least know... be careful! Keep it straight! Two 50 ft. stripes in the lot now!
    Be safe!:evo:
  8. rshelby
    Sounds like fun! :thumbsup:
    Nothing wrong with testing out the beast.
  9. rdrumm
    Anaheim Calif
    Yep, a little fun is nice... just want those lights and noises to go away! If I choose to step on it, I want the warnings to just go away!
    I'll play it safe now that I know what I'm driving! You got to know what you have under that foot! Am I right?
  10. salukifan
    salukifan Member
    did the boss see ya lighting them up?
  11. rdrumm
    Anaheim Calif
    I may be dumb, but not that dumb!:blush:
  12. Lifter583
    Lifter583 Well-Known Member
    I NEVER use the TCS...I always turn it off as I start the car...does nothing except wear out the rear brakes...and reduce the fun you can have!
